5/13/2020 5:30 PM | |
Joined: 3/30/2020 Last visit: 2/2/2023 Posts: 3063 Rating:
Hello Daniele, I hope you are well. The configuration here is different than what you had in the S7-1200. From your description you seem to be on the right track. The "encoder" feedback in this case is not an actual feedback from a physical encoder (opinion). I made a quick study of documents:
The configuration I did with an S7-1200 and ET200MP, but there should be enough of the same that would be helpful. My suggestions are highlighted in the ZIP file as pictures. Hopefully someone can confirm these for us later on. Does these notes help? Attachmentcapture.zip (89 Downloads) |
5/14/2020 9:02 AM | |
Unfortunately that is all I am able to give you.
Good luck. |
