12/2/2023 3:12 PM | |
Joined: 9/27/2006 Last visit: 4/18/2025 Posts: 12346 Rating:
Hello Mehdi; Have a look at this document, it is based on TIA Portal v13, but you should be able to follow its guidance on a more recent version of the software. The ghardware used fr the example is a Comfort panel, but it is stated in the documentation that you can replace that with a WinCC Advanced system.
Hope this helps, Daniel Chartier |
