12/28/2017 11:23 AM | |
Posts: 9 Rating:
Hi dear expert i have 2 question : 1- would you please convert this project to TIA portal v13? my "migration to tia " doesn't work (it says you need step7 v5.5, but step7 v5.5 can't install in win7 64 bit
2- I have an ABB ACS800 with RPBA profibus dp card and an op177b simatic HMI. i want to control drive direct from hmi. may network is profibus dp. is it possible? I found some manual for micromaster drives, but abb drive setting is different. any suggestion? (link) thanks a lot ------------------------------------------------------------------------------------------ |
Last edited by: CS Moderator at: 12/31/2017 10:57:16 AMNew subject after splitting |
12/28/2017 11:25 AM | |
Posts: 9 Rating:
Hi dear expert i have 2 question : 1- would you please convert this project to TIA portal v13? my "migration to tia " doesn't work (it says you need step7 v5.5, but step7 v5.5 can't install in win7 64 bit). 2- I have an ABB ACS800 with RPBA profibus dp card and an op177b simatic HMI. i want to control drive direct from hmi. may network is profibus dp. is it possible? I found some manual for micromaster drives, but abb drive setting is different. any suggestion? (link) thanks a lot |
12/31/2017 10:58 AM | |
Joined: 9/1/2005 Last visit: 5/24/2023 Posts: 4099 Rating:
closed cause question posted twice. The second thread with the subject direct connection between simatic hmi and ABB drives via profibus dp is published within the conference SIMATIC Panel Best regards |
