6/9/2011 11:59 AM | |
Posts: 122 Rating:
Hi everyone, I undestand it's not possible to convert SCL code to STL, but is there any way to convert SCL to FBD or LAD? Thaks Splitted from Conversion of SCL to STL. |
6/9/2011 7:55 PM | |
Posts: 122 Rating:
Thanks for your answers I will try the method you explained. |
6/10/2011 9:28 AM | |
Posts: 122 Rating:
Hi hdhosseini I'm sorry to bother you again but I'm trying the method you suggested and I'm having some trouble. It's the first time I work with SCL and I'm following the steps you gave me: compile the code and then delete de source file, but after that, where can I see the code in STL? Thanks in advance |
6/10/2011 10:48 AM | |
Joined: 1/28/2009 Last visit: 5/26/2023 Posts: 6802 Rating:
Hi Check the attachment for more information AttachmentSTL.zip (359 Downloads) |
Last edited by: O_Moderator at: 6/10/2011 9:43 PMattachment edited Last edited by: hdhosseini at: 6/10/2011 9:07 PMLast edited by: hdhosseini at: 9/9/2018 9:28:16 PM |
