6/15/2011 10:49 AM | |
Posts: 35 Rating:
EXPLIQUER MOI D'OU PROVIENT LES 27648 ?
Attachmentconvesion valeurs analogique dans step7.zip (107 Downloads) |
6/15/2011 12:28 PM | |
Joined: 1/28/2009 Last visit: 6/8/2023 Posts: 6805 Rating:
Check the attachment to how convert raw converted digitized value(0 t0 27648) to the meanigful physical value in user program. Use of scale functionregards |
6/15/2011 1:28 PM | |
Joined: 3/21/2006 Last visit: 4/12/2023 Posts: 10221 Rating:
Take a look at How 27648 Analaog Maximum Value ? Best regards, Hristo MIhalev |
6/15/2011 3:32 PM | |
Posts: 35 Rating:
MY QUESTION IS SIMPLE: what is the meaning of 27648 oterwise from where it comes.
Attachmentconvesion valeurs analogique dans step7.zip (49 Downloads) |
6/15/2011 3:37 PM | |
For analog to digital conerter circuit inside the Ai card there is a hardware implementation to convert for example 0 to 4 mA to a digitized values.The hardware algorith maps 4 ma analog to 0 digital and 20mA analog to 27648.This value is set due to technical spec of manufacturer. Please note that the Digital to Analog converterinside AI convert this range of physical values to a WORD.In ALLEN BRADLEY controllers, the conversion is done from 0 t0 32767(0 t0 w#16#7FFF) and just one bit is reserved for error or sth(They also provide diagnostics data seperately).In HIMA as safety controller this conversion done from 0 to 700. For more information check chapter 4,5,6 of the following manual. SIMATIC S7-300 S7-300 Automation System Module Data regrads |
5/22/2012 2:03 PM | |
Joined: 5/1/2009 Last visit: 5/23/2021 Posts: 144 Rating:
Attachment14 Analog Value Processing.zip (87 Downloads) |
Best regard |
