10/20/2023 8:56 AM | |
Joined: 7/19/2022 Last visit: 4/17/2025 Posts: 436 Rating:
Hello Colin Malcolm, First of all, I recommend taking a look at the following links: How do you migrate a project integrated in STEP 7 from WinCC flexible to WinCC (TIA Portal)? It is recommended that the TP270 panel should be migrated to the TP700 if it is the 6'' panel or to the TP900 if it is the 10'' panel. |
