5/26/2011 12:15 PM | |
Joined: 5/13/2008 Last visit: 12/18/2019 Posts: 836 Rating:
Hi Pavel, you have to use another PC in the same ethernet based network, to handle the FTP copy job. Important: Only the panel can copy files from a PC to the panel itself, it is not possible tocopy a file initiated by the PC. These FAQ's may help you: http://support.automation.siemens.com/WW/view/en/26437181 http://support.automation.siemens.com/WW/view/en/13336639 |
mfG / Best regards |
6/6/2011 9:54 AM | |
Posts: 148 Rating:
Use to HTML Browser to view it over network (FTP, HTTP,......) without copying it to HMI . It works with me see attachment AttachmentPICs.zip (250 Downloads) |
6/9/2011 8:42 AM | |
Posts: 26 Rating:
Hi, it looks great but I don ´t have html browser in my enhanced objects:/ Probably the OP277 doesn´t support that. Can I add it by any way? Thanks a lot. Pavel |
6/9/2011 12:10 PM | |
Posts: 148 Rating:
What is your " Simotion" system is ? |
6/18/2011 4:11 PM | ||||||||||||||||||||
Posts: 148 Rating:
what about GetObject Function ? I have to read more about the class of object but NO time
