6/29/2018 9:47 AM | |
Joined: 1/15/2018 Last visit: 5/17/2022 Posts: 138 Rating:
Hi, I need to copy one file (recipe) from a HMI (TP1900 Conform) to a PC via Ethernet. I created a sript that do that when a variable change (trigger):
The problem is that it take around 4/5 min to copy a file of around 300 KB. The HMI execute just this script and has about 1200 variables. It has 9 PLC connections in other network (we use other port for that). Do you know if it is normal to take this time? How could we improve its performance? Thank you very much! Best regards, Gonzalo |
