6/5/2011 8:58 AM | |
Joined: 7/8/2009 Last visit: 8/5/2024 Posts: 1976 Rating:
You dont need to do Copy RAM to ROM as in 315 CPU, program is always stored in MMC card.. Regards Devesh |
I dont Like people driving Fast, thats the reason I overtake them ;) |
6/5/2011 10:22 AM | |
Joined: 2/6/2009 Last visit: 3/26/2025 Posts: 939 Rating:
Hi, I don't thing so, it will be possible to take the program when it is protected. If the protection is only set for Write protection, then you will be allowed to read the data from the CPU. Here is the attachment which shows the protection method used in one project
_______________________________________________________________ |
6/5/2011 10:31 AM | |
Joined: 3/18/2008 Last visit: 12/8/2023 Posts: 1750 Rating:
Dear Kumar, Udara want to make a backup of program to MMC which is not Required to do as it happends automatically. When you download a program to CPU,MMC auotmatically takes the Backup. Hence Copy is not required as said by Vithani. |
VANDE MATARAM..... |
6/5/2011 12:03 PM | |
Posts: 691 Rating:
The program can be uploaded to the Engineering PC having Siemens Softwares If its PLC then Step 7 will be sufficient. |
6/5/2011 12:55 PM | |
Thank you all for responding.. But as Amit said, Udara wants to know that if it is Possible to do Copy RAM to ROM if MMC card is Password Protected.. Thats why I replied that It is not needed as program is already in ROM-MMC card.. I hope its clear Now.. Regards Devesh Vithani |
6/5/2011 3:35 PM | |
Hi Amit, Sorry for the wrong understanding. Actually what I though was, Udara wants to take a backup in another MMC card. So that only said the method to take backup is PC first and once he insert the new MMC he can download it in future.
Last edited by: Saravana kumar at: 6/5/2011 3:37 PMLast edited by: Saravana kumar at: 6/5/2011 3:37 PMLast edited by: Saravana kumar at: 6/5/2011 3:37 PMLast edited by: Saravana kumar at: 6/5/2011 3:37 PMLast edited by: Saravana kumar at: 6/5/2011 3:37 PMLast edited by: Saravana kumar at: 6/5/2011 3:37 PMLast edited by: Saravana kumar at: 6/5/2011 3:37 PMLast edited by: Saravana kumar at: 6/5/2011 3:37 PMLast edited by: Saravana kumar at: 6/5/2011 3:37 PMLast edited by: Saravana kumar at: 6/5/2011 3:37 PMLast edited by: Saravana kumar at: 6/5/2011 3:36 PMLast edited by: Saravana kumar at: 6/5/2011 3:36 PMLast edited by: Saravana kumar at: 6/5/2011 3:36 PMLast edited by: Saravana kumar at: 6/5/2011 3:36 PMLast edited by: Saravana kumar at: 6/5/2011 3:36 PMLast edited by: Saravana kumar at: 6/5/2011 3:36 PM_______________________________________________________________ |
6/5/2011 4:13 PM | |
Joined: 10/7/2005 Last visit: 4/3/2025 Posts: 3046 Rating:
But what if Udara wants to make sure that he has the latest actual DB values backed up on the MMC? In that case "Copy RAM to ROM" is actually quite useful and moreinfo on all things related to this can be found in the FAQ below: What is the effect of the STEP 7 function "Copy RAM to ROM"? @Udara: As for your orignal question, I'm afraid I can't tell you if "Copy RAM to ROM" will work when the PLC is password protected (never tried it and don't have a CPU handy right now to test it). I'd say simply give it a try (it either works or it doesn't) and let us know what the result is. I hope this helps |
Cheers |
2 thankful Users |
6/5/2011 5:13 PM | |
Posts: 947 Rating:
Hi I Thing "copy ram to rom" work on old CPU with old Eprom(EEPROM). This is not flash Eprom. Formake backupMMC card need insert MMC in cardreader and make bit to bit file image. |
6/5/2011 6:58 PM | |
hello Gre_m Copy of MMC Card through Card reader. Good thinking. Have you checked through Card Reader? it is working then wonderful idea. |
6/5/2011 7:09 PM | |
Posts: 691 Rating:
You can read the MMC cards through Card Reader. I did that to take out GSD File from SINAMICS DC Master. But never tried with S7 CPU MMC Cards |
