6/30/2017 8:25 AM | |
Posts: 50 Rating:
Hello Folks, I have the similar problem. I want to copy the Audit Trail log file from the TP700 comfort panel SD card to the central SCADA PC. I have created a shared folder in the SCADA PC witch will be accessed by the HMI for File copy. There is a trigger in the HMI, on which the file copy will be done. The audit Trail is continuously logging in the SD card in HMI. The audit trail file will be copied / overwrite every time to the PC, not moved. If anybody have any idea, please share. Thanks in advance. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 6/30/2017 1:00:02 PMNew subject after splitting |
