12/6/2013 4:44 PM | |
Joined: 1/28/2009 Last visit: 11/18/2023 Posts: 6822 Rating:
Hello, SFC20 is used for mass copy of data pointed by source input and copy them to target area.If you are working on peripheral addresses, using SFC20 is not possible,The alternative solution in those cases is using indirect addressing and loops(for S7-300/400).If you search the forum, you will find some discussion and STL codes for that. How do access the I/O address area indirectly and what should you watch out for when copying with the SFC20? I hope this helps you Hamid Hosseini |
