4/6/2009 5:45 AM | ||
Posts: 58 Rating: (0) |
Hi UMENCHO, Yes I using a unique PC (Laptop IBM T43) and I think all hardware is OK becauseif I use Step5 V6.6 to connect to PLC S5 it's OK ( Pls, see the attached files). The Step5 I try to connecthave version is 7.23 and service pack 1 Hi Thijs, Why I need to oder new USB-TTY cable, Why The Siemens TTY-RS232 Can not use ?! Hi Zenta, Pls, see the attached file to view my setting for com port, If I changed the comport to Port 3 as you said, the same problems !
huhu... Ban AttachmentDocument.pdf (968 Downloads) |
4/6/2009 9:43 AM | |
Joined: 4/24/2006 Last visit: 10/10/2024 Posts: 8745 Rating: (1168) |
Hi ntban, Perhaps this document can help. Best regards, Wizard Attachment5 Simple Steps to Configure Serial to USB conversion on St…[1].pdf (1455 Downloads) |
4/7/2009 5:54 AM | |
Thanks Wizard, I do the same in your document , but it's still error ?! Pls, see the attachment picture for the message info about the error ! Hic hic... |
4/7/2009 9:32 AM | |
Hi ntban, Perhaps this link might help: http://support.automation.siemens.com/WW/view/en/18548070 Best regards, Wizard |
