11/14/2013 5:14 PM | |
Posts: 81 Rating:
Hi all, Can anyone guide me what these status LEDs reflect Diag - "Flashing Green" Network - Steady green Signal - Steady Green Others - Off Regards, Haris |
11/14/2013 6:07 PM | |
Posts: 510 Rating:
Here are the pages from the manual on the LEDs. They should answer your questions. Good luck, billwest AttachmentC:\Users\westwd\Documents\Pages from BA_CP-1242-7_76.pdf (347 Downloads) |
11/15/2013 9:14 AM | |
Posts: 81 Rating:
Hi, I read the manual - I couldn't find a combination with Diag Flashing green and Network steady green. Any idea what it could mean? Regads, Haris |
11/15/2013 4:21 PM | |
Posts: 510 Rating:
Since I am unsure of your application, here is a link to a Siemens Application example for the CP1242-7 and Telecontrol: http://support.automation.siemens.com/WW/view/en/39863979 It includes an example project and documentation. At the bottom of the link is "Further information" which includes links to four similar applications, Set 31 through Set 34. You should be able to find an example that closely approximates your application. Review the documentation to troubleshoot your application. Good Luck, billwest |
