9/3/2006 6:31 PM | |
Joined: 1/7/2006 Last visit: 11/17/2023 Posts: 2705 Rating:
Hi Carlos, Before I forgot to say it, please use the right cable where you can use a crosscable with on one side a 15p D-plug and on the otherside a RJ45 plug... For the CP1413 is an older windows necessary, see the document that I attachet. You need then also older NET-Software, there could be a problem because the CP1413 is only working under Windows NT4 SP6a. The software for the CP1413 is discontinued somewhere in 2004, see the link: AttachmentNET_OS_CP_e.pdf (674 Downloads) |
