1/19/2007 11:30 AM | |
Posts: 95 Rating: (0) |
Can I obtain a link to a CP340 manual ? Many thanks. |
1/19/2007 1:14 PM | |
Joined: 4/24/2006 Last visit: 1/23/2025 Posts: 8808 Rating: (1177) |
Hello alexfizeau, Here are some links: http://support.automation.siemens.com/WW/view/en/1137332 http://support.automation.siemens.com/WW/view/en/16527390 http://support.automation.siemens.com/WW/view/en/12108826 I hope it will help you. Best regards, Wizard |
1/19/2007 2:19 PM | |
Hello Roby, You use the links earlier mentioned, then go to right bottom. Here you see 'More Languages', here you can select desired language Here is one example link: http://support.automation.siemens.com/WW/view/en/1137332/0/it Hope this will help. Best regards, Wizard |
1/19/2007 2:51 PM | |
You are welcome Greetings Wizard |
1/30/2007 10:55 AM | |
Hello, Why don't you use ASCII protocol? Here is a link to example: http://support.automation.siemens.com/WW/view/en/8797119 Unfortunately it's not for free to download. They use ASCII protocol and Hyperterminal to communicate between CP340 and PC. Best regards, Wizard |
1/30/2007 1:04 PM | |
I am using 3964(R) protocol because it offers data integrity and I personally think it is more safe for the process |
