10/9/2005 5:48 PM | |
Posts: 102 Rating:
Dear Mr. Tophe I am trying to communicate 1SI module from et 200s modules with energy meters on modbus rtu protocols I have been able to read the holding registers . You try downloadingf the zxx21_1 example file from www.support.automation.siemens.com and you will be able to do that ar else get in touch with me via private message. I will send you the program i have used for the same which will help you |
