9/25/2017 12:41 PM | |
Joined: 8/3/2009 Last visit: 3/21/2025 Posts: 15056 Rating:
Hello Saravana kumar In this FAQ they wrote that you need CP1613 or CP1623 and that its not possible with normal Ethernet Cards: https://support.industry.siemens.com/cs/ww/en/view/16667714 Bye Murof |
9/26/2017 3:51 AM | |
Joined: 2/6/2009 Last visit: 1/7/2025 Posts: 939 Rating:
Hi, Thanks for the reply. The attached document is of old version, I am able to create fault tolerant connection via IE General card using CP 443-1 ( 1EX30), But it doesn't work for CP 443-1 ( 1EX20).
_______________________________________________________________ |
