5/21/2011 8:37 PM | |
Joined: 10/5/2006 Last visit: 3/24/2025 Posts: 74 Rating:
I found an article relating to the CP 342-5 (part# 6GK7-342-5DA02-0XE0) module. Afirmware update corrects the following symptom: "Problem in the case of a repeated download of the configuration to the CP (CP sporadically remained in STOP)" Here is a link to the information : http://support.automation.siemens.com/WW/view/en/19726245 Now there is a later version of firmware available V5.7: http://support.automation.siemens.com/WW/view/en/24104930 Again, this applies if you have part# 6GK7-342-5DA02-0XE0. Regards, Shawn |
Automation Programmer |
