5/15/2013 10:31 AM | |
Posts: 118 Rating:
Hi Raheel, the CP 1242-7 GPRS buffers the data, so that the data will be sent when the connection is established again. But I think that data bufferingonly works if you use a PC withthesoftware Telecontrol Server Basic, so all data between the RTUs are sentto each otherviathis server or you can just send the data only to this server. There are some examples in the link below which might be helpful: http://support.automation.siemens.com/WW/view/en/58099765 |
