6/16/2016 11:51 AM | |
hi Gaurav, okay, I got you. But on this way you are limited to 10 messages. And the numbers are assigned to the projected messages. But when you use the blocks, like I told you, it shoud be possible to send more. with V2 you can use other blocks, the normal blocks for Open User Communication. Have a look in the manual, chapter 5: SIMATIC NET S7-1200 - TeleControl CP 1242-7 GPRS V2 - Operating Instructions You have to connect to one recipients, send the message, and disconnect. One after another, 25 times. hope this helps, |
FCK WAR! |
