8/9/2024 10:32 AM | |
Joined: 5/30/2022 Last visit: 9/16/2024 Posts: 575 Rating: (95) |
Hi RDVD84, 1- What is the exact version of SIMATIC MANAGER you are using? It is possible that only this firmware version appears in the latest versions. 2- You can also try to install the STEP 5.X HSPs to check if it appears in the catalog: |
If this information really helps, you could use the Rate function. |
