4/22/2008 11:26 PM | |
Posts: 5822 Rating: (412)
Hello, well this is not that big thing. If you read the Manual: CP 243-2 AS-Interface Master in chapter 5 you will find the Command interface. There is a option to change the AS-i Slave Address. If this is the only parameter you have to change than this is the easiest way. All other Parameters can be changed too. This chapter contains everything you need... I think. Best regards J_Bell |
