4/24/2008 9:54 AM | |
Posts: 7 Rating:
So you used the code supplied with the document? How? Just put it in your project and start the FB? Of course changing the data in the corresponding data block. |
4/24/2008 12:22 PM | |
Posts: 7 Rating:
Thanks Ton Verra I'll try it out. I guess the example won't work with the CP340 since it has its own FB for sending data (P_SEND) but I hope I'll see how is the sending executed. I tried using the example from here: https://support.automation.siemens.com/GB/llisapi.dll?func=cslib.csinfo&lang=en&objid=25545680&caller=view |
