6/16/2013 12:06 AM | |
Joined: 9/27/2006 Last visit: 3/20/2025 Posts: 12344 Rating:
Hello Gowda; Does your PTP partner support 3964R or ASCII protocols? Look at the table in the following FAQ, you will see that these are the 2 protocols available with the CP 340: What protocols for the point-to-point connection are supported by CPs in S7-300 / S7-400 and where can you get further information? Hope this helps, Daniel Chartier |
6/17/2013 9:11 AM | |
Posts: 112 Rating:
i have used the LIBRARY blocks of FB2 and FB3 i have called FB2 and FB3 P_RCV P_SEND but how to transfer the data to specfic address of DCS wether we have to check CRC and how to identifey the SLAVE or THIRD PARTY ID any extra programing have to do for it .........for error checking |
6/17/2013 1:33 PM | |
Posts: 112 Rating:
Dear dchartier Thanks for your kind replay. you have explained simple way ............. Its more helpful to understand |
7/2/2013 6:27 PM | |
Joined: 4/17/2012 Last visit: 2/25/2025 Posts: 474 Rating:
Hi, please see the attachment and this link AttachmentMODBUS GENERAL DESCRIPTION.pdf (235 Downloads) |
7/2/2013 7:04 PM | |
Hi, Now you finalised which method of data transfer is going to do RTU, RK512 ???? here i am giving one sample logic which i downloaded from forum only but it will helps you
AttachmentMODBUS_V5.0.zip (237 Downloads) |
