1/5/2010 1:17 PM | |
Joined: 10/7/2005 Last visit: 3/20/2025 Posts: 3042 Rating:
Hello Solution Riders which FB you need (i.e. FB81 "S_MODB" in your MB Slave case) and how use it as well as how to set up the 1SI Modbus Slave is quite well explained in the ET200S Serial interface manual (you can find it as well as the FB's and examples HERE). While I hope this helps, the real question - in my humble opinion - is: Why would you usea Modbus RTUlink between two S7 PLC's??? |
