9/20/2011 2:36 PM | |
Posts: 9 Rating:
Hi , I use a cp341 for comunication with one trasmitter and onme PLC 3152DP , the trasmitter send contuos data in rs422 ( ascii format ) in the cp341 i have rx led gren and blink the tx . I think not need to use the P_SND_RK FB 8 but only the P_RCV_RK FB 7 is correct ? I have try to use the FB7 parametrize the data but not have NDR . I have check the configuration of paramater and think all OK , sure I make mistake but non say where. thank's in advantage. Best regards Claudio Splitted from CP 341. |
9/21/2011 1:25 PM | |
Posts: 9 Rating:
OK But my trasmitter , send in continuos the data not need to ask nothing , infact I have the RX led in CP on and some time blink the RX , my problem is non have found the way to receive the data. the trasmister work in rs422 38400 Baud , 7Bit ,parity even and use hex 04 end caracter of string. I have test some setting with end caracter and none , with xon/xoff and none ,but in the fb7 not have done at 1 have no error and the status is 00 , i think make some wrong but not say where. i have attached the manual of trasmitter thank in advantage best regards. Claudio Attachment120244.pdf (203 Downloads) |
