3/6/2011 6:27 AM | |
Joined: 12/14/2010 Last visit: 1/12/2025 Posts: 117 Rating:
Dear Experts As i have facing problem in EM6400 conzerv meter.I could not getting proper
value of watt hourparameter from EM6400 and iam getting remainingparameter and all properly.But partcularly problem in watt hour parameter.
Watt hour parameter increasing gradualy in that meter.
But while inPLC side that same Watt hour paramter value some times matching with meter value,some times decreasing after some time it is increasing, it indicates malfunction of meter. Also here i with attached screen shot ofEM6400 watt hour parameter trendfor your reference. I request you to kindly provide the solution for rectify the above mentioned the problem. And also i checked this meter with modscan32 software,it showing proper value keep on increasing. AttachmentWh Trend.zip (147 Downloads) |
2/9/2018 10:01 AM | |
Joined: 9/28/2013 Last visit: 12/5/2024 Posts: 10 Rating:
No dear I am facing problem with all em6400 energy meter |
2/9/2018 1:31 PM | |
Could u explain how to convert watt to kwh value in plc logic.as I m getting accurate value of watt from the meter |
