11/26/2012 3:45 PM | |
Posts: 4 Rating:
I use cpu 312 which have two cp 341 . The first address is 256 ( put dongle modbus master ),the second (put dongle modbus slav ). I program to communicate each other between two cp 341 but not wok and show error 830. I did all instruction manual and I found the same error 830 again . What should I do? I will attach you the program and could u check db 44(source data) that is it sending the right message?
AttachmentModbus master test.zip (157 Downloads) |
11/26/2012 4:27 PM | |
Posts: 4 Rating:
ThankKaulquappe i have done it already. it did not work what should i do next?
AttachmentModbus master test.zip (148 Downloads) |
11/28/2012 5:04 PM | |
Posts: 4 Rating:
I followed your suggestions and I could connect with analyzer and get the data but show error as list below. Diagnostic buffer of module CPU 312 Order No./ Description Component Version 6ES7 312-1AE14-0AB0 Hardware 4 - - - Firmware V 3.3.7 Boot Loader Firmware expansion A 32.9.9 Rack: 0 Slot: 2 Serial number: S C-C8UF15992012 Event 1 of 10: Event ID 16# 2521 BCD conversion error Affected register: accumulator 1 Requested OB: Programming error OB (OB121) Priority class: 1 Internal error, Incoming event 12:48:48.495 PM 11/28/2012 (Coding: 16# 2521 0179 0074 0000 0000 0000) However PLC can work normally . How can I edit and recorrect them? Please suggest me. AttachmentDi.zip (149 Downloads) |
