1/18/2012 7:15 PM | |
Joined: 4/22/2010 Last visit: 2/26/2025 Posts: 5697 Rating:
Hello, You can download HSP's here http://support.automation.siemens.com/WW/view/en/23183356 In case your V is not there you can update your firmware: http://support.automation.siemens.com/WW/view/en/24435323 Are you sure about that V2.3? But you should also be able to use the card with an earlyer firmware version, only if there are new functions these will not work. Regards, Marcjan |
1/18/2012 7:53 PM | |
Joined: 1/27/2009 Last visit: 2/24/2025 Posts: 42 Rating:
Hi Marcjan, I already download the HSP but there is no V2.3. Yes, i'm sure the firmware of the CP is V2.3 based on name plate. I'm trying to configure with V2.0 and V2.2 but not work (SF Led is on) both CPU and CP.
