11/8/2017 9:38 AM | |
Joined: 9/8/2015 Last visit: 3/11/2025 Posts: 122 Rating:
My card is : CP343-1 Lead >>>>V2.3<<<< There is not in the catalog!!! |
11/8/2017 12:33 PM | |
Joined: 8/3/2009 Last visit: 3/27/2025 Posts: 15107 Rating:
Hello Masoodes its strange I can use the Firmwareversion 1.0, 2.0, 2.2, 2.4, 3.0 but not V2.3 in TIA Portal V14??? and the Readyness Check tool tells me it s OK for TIA Portal .... In the Product note : https://support.industry.siemens.com/cs/ww/en/view/42122470 Is the Information that it should also work if you select V2.2 in Step7. Bye Murof |
11/11/2017 7:18 AM | |
I did it, but it's a Error! |
