1/30/2013 1:48 PM | |
Joined: 9/27/2006 Last visit: 3/22/2025 Posts: 12344 Rating:
Hello Sarfaz; You are mixing all kind of equipment here, from As-i slave nodes to blank plugs and As-i handhelp programmers. Kindly sketch how you are planning to build your network using these elements so we can understand wwhat you are trying to do. In the meantime have a look at the following documents and links: AS-Interface - Industrial Controls - Siemens Note: Module D1 is a sample training module for As-i connections to a CP 343-2 |
1/30/2013 2:21 PM | |
Joined: 4/14/2010 Last visit: 2/8/2025 Posts: 525 Rating:
Dear dchartier, thanks for message actually i want to connect two 3RK1200-0DQ00-0AA3, four 3RK1200-0CQ20-0AA3, one 3SF5813-0DA00 and one 3SF5813-2DE20 with CP343-2 6GK7343-2AH01-0XA0 module with help of 3RX9017-0AA00, 3RX9027-0AA00 and 3RX9501-0BA00. can i interconnect above devices with each other what is the assosated items required.?? is it cp343-2 supported for 40 digital inputs of sensors and Pushbutton stations..??? Thanks. |
MS |
