9/24/2008 8:57 AM | |
Posts: 70 Rating: (3) |
Hi - Step7 v5.4 should have the card installed ; se attached picture. To configure the serial protocol you need to install the CD which comes with the card (CP441 v5.1 SP8). http://support.automation.siemens.com/WW/view/en/27013524 If you dont see the cp441 in the hardware manager you should install the latest Hardware Pack http://support.automation.siemens.com/WW/view/en/23183356 Best of luck soren |
