12/17/2007 9:13 AM | |||||||||||||||||||||||||||||||
Posts: 124 Rating:
It's not so easy. Functionally CP5611A2 replace CP5412A2, but: 1. CP5412 is ISA, CP5611 is PCI 2. There are several drivers for CP5611 (you mustbuy the adequate driver for your application, probaly it was a S7-5412 and now Softnet S7), but I believe that the driver for WINNT is discontinued, so you should upgrade your system for Windows 2000, XP, 2003 or Vista and this means you should upgrade your Scada System too and probably your PC.
12/18/2007 9:05 AM | |
Posts: 2 Rating:
Although it is the bad news, Thank you very much for your reply and advise! |
