12/6/2007 7:46 AM | |
Joined: 3/21/2006 Last visit: 10/7/2024 Posts: 10229 Rating: (1181) |
Hi First of all you need to synhronized the cp544 and cpu. But maybe this is done in your system. OB21, and OB22 is for that. My advice is to add and OB20. After this synhronized you need COM PP parameterization software, installed on PG with step 5. With this software you will make CP 544 Parameter Sets. And if is done correctly your programm must work. Maybe this FBs is for communication. You can read more: SIMATIC S5 Manual CP 544 regards |
Last edited by: UMENCHO at: 06.12.2007 08:01Yes, I think CP544 backup is required to run system properly . |
