2/15/2007 9:45 AM | |
Joined: 4/24/2006 Last visit: 4/25/2025 Posts: 8969 Rating:
Hello Donflore, There are some known problems with CP5511: Have you seen these faq's: http://support.automation.siemens.com/WW/view/en/2827787 http://support.automation.siemens.com/WW/view/en/2331034 http://support.automation.siemens.com/WW/view/en/856884 http://support.automation.siemens.com/WW/view/en/12259435 When you connect to CPU only, is it working then? Do you have the right Profibus parameters used for CP5511? Best regards, Wizard |
2/17/2007 7:24 PM | |
Posts: 324 Rating:
Hello, just as an idea, maybe you may use a USB Adaptor instead, this usually works, especially with S7-200 Systems. Stay calm. [:)] |
