2/28/2008 2:40 PM | |
Posts: 145 Rating:
We are receiving some errors - 0x031a / 0x031b (screenshot attached). We tried the remedy found in the FAQ with the title : "How do Diagnostics and Remedy work in in STEP 7 when an online connection with the CP5511 is not possible?" However, it didn't solve our problem. We tried with both Access Points (MPI + S7 Online). We reinstalled the CP5611, but again the same errors. The cable that connects the card and the PLC has been tested and it is ok We changed both the Station Address Number and Timeout (Set PGPC Interface -> Properties -> Station Parameters ) but again the same errors. What might be the error? Is there any idea? Thanks in advance for your time AttachmentCP5611_Error 0x031a_b.zip (490 Downloads) |
2/28/2008 3:59 PM | |
Posts: 145 Rating:
Hello J_Bell, Thanks for your quick reply and the relative information about how to establish the MPI network. We have already tried this solution but it didn't help. The screenshot you are referring is from the WinCC Explorer (Tag Management-> SIMATIC S7 Protocol Suite -> MPI => Right Click -> System Parameter). However, now we are receiving some different errors after reinstalling the SIMATIC Net software. We have also attached them. Is there any idea what else can we try? Thanks in advance AttachmentSIMATIC Net_errors.zip (277 Downloads) |
1/29/2009 8:57 PM | |
Posts: 38 Rating:
Does anyone have any ideas on how to fix this issue. I am very desperate and any help would be greatly appreciated! Thanks! |
