3/28/2017 12:41 PM | |
Joined: 5/12/2006 Last visit: 6/7/2023 Posts: 21510 Rating:
Hello, why you don't use the successor 6GK1561-2AA00Regards |
3/28/2017 2:21 PM | |
Joined: 4/28/2015 Last visit: 6/5/2023 Posts: 9534 Rating:
Hello, look to eBay or other similar site. |
With best regards... |
3/28/2017 3:01 PM | |
Posts: 167 Rating:
The mainboard we need to use are not supporting PCI-X... Will take a look at ebay, thank you all. |
3/28/2017 3:29 PM | |
Hello, sorry i mean CP5612. CP5611 / CP5611 A2 = PCI, no longer available CP5612 = PCI, successor of the CP5611 in this FAQ you find the supported Slots for CP's: https://support.industry.siemens.com/cs/ww/en/view/15350579 Which Mainboard do you use? Can it be that no driver was installed for the CP5612 CP? Regards Christoph |
3/28/2017 3:42 PM | |
Joined: 9/27/2006 Last visit: 6/6/2023 Posts: 12036 Rating:
Hello; Here is the technical datasheet of the CP 5612, recommended by ChristophD earlier: https://support.industry.siemens.com/cs/pd/451771?pdti=td&lc=en-FR It states that the module format is PCI. The same information is found in the operating instructions for this CP: SIMATIC NET PG/PC - PROFIBUS CP 5612 Operating Instructions Hope this helps, |
