12/8/2009 6:05 PM | |
Posts: 5822 Rating: (412)
Hello, how about this little document which is usually part of your CP 5613 / 5614 installation. By the way, just replace the CP 5611 used in this document with your CP... that's it. Best regards J_Bell Attachmenten Application DP Master.pdf (111 Downloads) |
12/9/2009 7:50 AM | |
Posts: 10 Rating: (0) |
Thank you for the reply. I found out the my settings wasok, but the slave I have was disordered. So every things works fine now. Best Regards Mikkel Fog |
Thank you for the reply. I found out the my settings wasok, but the slave I have was disordered. So everythings works fine now. Best Regards Mikkel Fog |
