1/30/2013 4:01 PM | |
Posts: 5 Rating:
Thank You Rainer -=-=-= Hello Chuck, I perfectly understand your demand. The requirement is known and we will support active information about available updates in a future version of the TIA Portal. If you want to inform yourself Step 7, the perfect entry point is: http://support.automation.siemens.com/WW/view/en/47531658 In order to support the 1215 CPU, you need a so called hardware support package (HSP): http://support.automation.siemens.com/WW/view/en/58344651 I hope this helps Rainer |
