11/5/2012 5:14 PM | |
Posts: 133 Rating: (2) |
MMC 64KB,cpu work memory 96kb; when i try to download something new a messagge says something like:memory needed/availabele/totaly/ 2053/2000/64k |
11/5/2012 6:37 PM | |||||
Joined: 9/27/2006 Last visit: 9/13/2024 Posts: 12282 Rating: (2683)
Hello automation_1; A rule of thumb that is always practical: load memory should be 1.5 times (approximately) the size of work momory for a S7-300. Larger if you want to hold a big program or you want to insert external files (such as the archived program for later retrieval, for example. Your work memory is 96 kb; the 1.5 rule would require a 144 kB MMC, which does not exist. So either you choose a 128 kB MMC and take your chances, or you go to the nearest larger model, at 512 kB.
Daniel Chartier |
11/7/2012 7:47 PM | |
very clear Thanks |
