11/12/2016 10:31 AM | |
Posts: 310 Rating: (18) |
Hello nealcj, Do u checked hardware configuration is correct .?? And How you are checking the analog output . Is its Multi meter . ??
Regards, Arasan.
11/12/2016 10:38 AM | |
Posts: 7 Rating: (0) |
Hi, We test the card output using multimeter and how can I check hardware config/setup? Thanks |
11/14/2016 2:28 PM | |
Joined: 5/6/2010 Last visit: 9/2/2024 Posts: 1978 Rating: (275) |
Hello nealcj, you can send the card to siemens or a other company which repair this cards. I have never repaired a AO-card. For you error investigation here are a few links with documents which explain the functions Programming the CPU 315-2DP Tests and online functions This should help you by your investigation with not so much experience in Step7. And here is also a link for training documents I hope this is a good support for you. regards |
