5/4/2016 1:03 PM | |
Joined: 6/5/2014 Last visit: 4/25/2021 Posts: 109 Rating:
if i update the firmware of the CPU to V1.2.1 did these limited numbers increase ? |
5/4/2016 1:18 PM | |
Joined: 7/2/2008 Last visit: 9/27/2023 Posts: 928 Rating:
Hello Mahmoud, If I may ask, how do you know that you use all available local data?!
No, the local data and S7 timers are part of system memory that can't be increased and can't even be altered in this particular CPU. As an alternative (already mentioned above) you can create data blocks in CPU's work memory. You can use IEC timers and counters. Tips and tricks for reading and comparing date, time and counters Best regards, H-H |
Last edited by: H-H at: 5/4/2016 1:20:30 PMOh! I was quite late. Maybe you will find the links useful. |
