7/25/2016 1:24 PM | |
Joined: 4/24/2006 Last visit: 9/13/2024 Posts: 8736 Rating: (1168) |
Hello, What is the MLFB number of used CPU? (6ES7...) and what is Firmware version? Best regards, Wizard |
7/25/2016 4:27 PM | |
Posts: 5 Rating: (0) |
Order Code and Version is clear in Picture attached... well its 6ES7 316-2AG00-0AB0 and version 1.0 |
7/26/2016 8:41 AM | ||||||||
Hello, Please have a look at the technical specifications: https://support.industry.siemens.com/cs/nl/nl/pv/6ES7316-2AG00-0AB0/td There you will find:
So when you want more then 4 connections, you will have to shut down one static connection. (One connection is reserved for PG, so 3 left) Perhaps when you upgrade your firmware, you might get more. (When you select a CPU 316-2DP with fw 1.2, you have tab Communication and can make some changes) Here a link to download firmware: Operating system updates for S7-316-2 DP CPUs Best regards, Wizard |
