11/16/2013 8:49 PM | |
Joined: 12/18/2012 Last visit: 2/11/2022 Posts: 14 Rating:
Is it really, that the H-systems (based in CPU 400H) aren't supported in TIA Portal (v11, v12)?? |
11/16/2013 9:37 PM | |
Joined: 1/28/2009 Last visit: 12/28/2022 Posts: 6785 Rating:
Hello, To be honest ,I can not provide you a constructive suggestion.I suggest using "Support Request" for a clear answer.They may ask you to refer to the conventional solutions with WINCC-Flexible.Have a look here: How do you connect a panel to a SIMATIC H station?Best regards, Hamid Hosseini |
11/16/2013 9:58 PM | |
Joined: 4/20/2007 Last visit: 1/30/2023 Posts: 710 Rating:
I have a similar problem, can you please let us know when you receive a solution from support? |
11/18/2013 7:49 PM | |
Thank you! |
11/4/2016 1:11 PM | |
Joined: 8/21/2014 Last visit: 2/3/2023 Posts: 710 Rating:
New question published by Saranya10 is split to a separate thread with the subject GSD file for CPU 412-5H necessary?. Best regards |
