2/27/2007 11:21 PM | |
Joined: 1/7/2006 Last visit: 2/16/2023 Posts: 2705 Rating:
Hi Keebolt, You can update your Hardware, see the next Link for further information: Hardware Support Packages (HSPs)there you can download the file and install it as described in the next link, or directly download from internet when you are online when you have the possibility to go directly online with your programming device: How can you update the hardware catalog without direct Internet access? This function is from V5.2 upwards possible, please consider that newer functions of new components might not work with older versions of STEP7, this because the cards need a newer STEP7 to work!! |
