5/1/2008 6:07 PM | |
Posts: 2661 Rating: (279) |
John: I have not come across a single Excel table that gives you a direct correlation between I/O's and CPU selection. There are other criteria beside I/O count (like response time/communication load etc.) that should be taken in to account for CPU selection. Perhaps the following entries will help: S7-300 CPU 31xC and CPU 31x, Technical Specifications http://support.automation.siemens.com/WW/view/en/12996906 Differing information on the requirement of offline/ online memory http://support.automation.siemens.com/WW/view/en/13962087 regards |
5/1/2008 7:30 PM | |
Darius: You have explained this in a very clear way and I absolutely agree with you! Regards |
5/2/2008 1:17 PM | |
Joined: 9/23/2005 Last visit: 9/13/2024 Posts: 4347 Rating: (1446) |
Hi, The number of instructions for each IO point depends of the many factores: tecnology (machine, plant,et), library and standards used, experiences of the programer, tool (PCS7, CFC, SCL, LAD, STL, etc), etc. Any general aproach many cause very large imprecisions. I suggest you do yourself your standard . Do somoe configurations, and looks how many bytes them takes. There is a general calculator in the Siemens online catalog: https://mall.automation.siemens.com/DE/guest/index.asp?aktPrim=0&lang=en |
Denilson Pegaia |
1/25/2018 12:53 AM | |
Joined: 9/3/2014 Last visit: 9/10/2024 Posts: 9 Rating: (0) |
Dear, The link https://mall.automation.siemens.com/DE/guest/index.asp?aktPrim=0&lang=en, is not working. Will you please check the link |
1/30/2018 6:37 AM | |
Joined: 8/3/2017 Last visit: 6/11/2024 Posts: 1086 Rating: (53) |
Hi APKV, I think this link can help you: https://mall.industry.siemens.com/mall/en/ww/catalog/products/5000013?activeTab=configurator®ionUrl=WW Best regards, Noodles |
Please, check out the forum search to find already existing topics regarding your issue and to get some hints. |
