6/12/2009 9:41 AM | |
Joined: 6/13/2006 Last visit: 2/11/2023 Posts: 341 Rating: (24) |
Please look on following usefull FAQ: http://support.automation.siemens.com/WW/view/en/22866139 reagrds, rit03 |
6/12/2009 9:51 AM | |
Joined: 3/21/2006 Last visit: 1/14/2025 Posts: 10239 Rating: (1182) |
Hello Saravana Kumar,
Look at necessaries settings which should be done and differences when using CP342-5. http://support.automation.siemens.com/WW/view/en/18208090 There you can find also how to set this CP like Profibus master or Profibus slave. Hope this will helps. Best regards Hristo Mihalev |
6/12/2009 11:01 AM | |
Posts: 557 Rating: (64) |
hi Find the all possibility ON DP PORT MASTER-SLAVE. http://support.automation.siemens.com/WW/view/en/6518822 ON DP PORT MASTER-to-MASTER for master-master you require TO buy DP-DP COUPLER. On MPI port. you can use GLOBLE DATA COMMUNICATION On MPI port. SFC 67(X_GET),SFC78(X_PUT) REGARDS |
