2/20/2014 2:17 PM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating: (121) |
Hey, it is not easy ti read what you want to do. To coomunicate to S7 1200 you did not need "OPC". Normally, if you want to use a PC, you need only "WinCC Advanced" (not WinCC Professional). I think you need for the first time a consultant (Ask a siemens consultant). Or look to this site https://www.industry.siemens.com/topics/global/en/tia-portal/Pages/default.aspx?HTTPS=REDIR regards, |
2/21/2014 7:57 AM | |
Posts: 1299 Rating: (136)
Hello, you can make a project just like you did for hmi for the pc. in wincc you add runtime advanced or runtime professional, depending on the needs of your project. you have to install the software wincc runtime advanced or wincc runtime professional on the pc you use for the visualization. you also need a license for this software. you can downloada demo project for runtime advanced in this article: http://support.automation.siemens.com/WW/view/en/73468169 K!ke |
2/23/2014 12:55 PM | |
Posts: 18 Rating: (0) |
I've manage to do get the project to run on the WinCC Runtime but i can not get any communication between the PC and CPU1200 to work. Thanks Steve. |
2/23/2014 1:00 PM | |
Posts: 8946 Rating: (999) |
You select TCP/IP for PC/PG interface? IP adress correct? |
