1/12/2013 1:42 PM | |
Posts: 20 Rating:
Hi Expert, I want to setup a application for S7-300 and Drive. I use CPU313C (6ES7313-6CG04-0AB0) as DP Master and FCD300 as Slave. So, I wonder this CPU work fine on this case or not. Because, I saw any application someone use CPU315-2DP. However, I want to save my cost on this application. That is my concern Otherwise, what is difference config Network "PRO Typ1 Module Consistent PCD" and "PRO Typ1 word Consistent PCD"? Please advise me on this, or some documents.. Any advise Thanks
AttachmentProfibus_Config.pdf (194 Downloads) |
1/13/2013 3:56 PM | |
Joined: 3/21/2006 Last visit: 3/19/2025 Posts: 10239 Rating:
Yes, this type of CPU will works pretty good like DP master with FCD300. In Danfoss web page exist a sample project and you can use it...
More info at attachment. Best regards, Hristo Mihalev
AttachmentPROFIBUS.pdf (262 Downloads) |
