12/16/2014 8:54 AM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, If you do not save your Countervalue in a DB and load it from DB to counter at startup, counter will start at 0 every time you start the PLC. Solution: How can the counter values of compact CPUs and of the FM 350/FM450 counter module be made available again after a power failure? Regards, Marcjan |
Problem solved? |
